×Is there a way to populate fields of a task or story that is linked to an EPIC with the field designated in the EPIC?
such as FIX VERSION, PRIORITY etc
Hi Eleanor,
Yes you can copy the values of fields in an Epic down to linked Tasks by using Automation for Jira.
However, what type of project is it - Team-managed (Next-gen)? Or Company-managed (Classic Software)?
The project is Company-managed (classic software)
Thank you - will check the solution ( Automation for Jira).
You should be fine then with the Company-managed project.
Have found the solution thank you!
added automation -
Hi eleanor
We have the same requirement.
In edit issue fields section what did you do exactly?
Can you show the details?
Be careful using automations on such topics if you have >1 project set up (which usually should be the case)!
The number of available automations is ridiculously low and you can brick your automation setup quite fast.
Automation is a quite useful feature, the usage limits on the other hand are one of the worst ever published to the market.
I would like to copy the TEAM (plans team) from the epic to the story/task of an epic. Is that possible through automation?
