Insight Lookup objects in automation module
Krzysztof Hotiuk March 20, 2022
In automation module, there is a Lookup object to filter objects from Insight.
I have a custofield with id 10073 and name "User Name". this is a Inside's type custom field type
Object type name is  "UserList"
I need to find this one, where a "Name" attribute equals with value in custom field.
in Query I wrote:
objectType="UserList" and "Name" = {{issue.User Name}}
or:
objectType="UserList" and "Name" = {{issue.customfield_10073.value}}
and other combination..
all cases I've tried ends with error message:
{"errorMessages":["IQL \"objectType=\"UserList\" and \"Name\" = and objectSchemaId == 5\" has invalid syntax at position 39 with error message \"extraneous input 'objectSchemaId' expecting {<EOF>, ' '}\""],"errors":{}}
(or similar)
What is proper syntax or how to get results I need?
Krzysztof
Dirk Ronsmans
Hey @Krzysztof Hotiuk ,
As you can see in the error the IQL you are trying to get to is resolving to:
meaning that your customfield value is not being pulled/resolved.
Since customfield_10073 is an Insight custom field I would suggest trying to use:
{{issue.customfield_10073.label}} or {{issue.customfield_10073.Name}}
Hi @Dirk Ronsmans
Thanks for your answer.. yes, it works now!
next question related smart values...
from object a need get value from attribute "Email" and to new object only prefix.
ex. Email attribute value is: kh_makii@makii.pl
in new object I need only: kh_makii
I've tried with this:
{{lookupObjects.Email.substringBefore("@")}}
but.. dosn't work :(
any Idea?
Dirk Ronsmans
is the lookupObjects actually returning something and if so what?
i would suggest doing a "log" action and go step by step. First output the full attribute to be sure that it returns something and then start cutting it up.
Like Bill Sheboy likes this
Krzysztof Hotiuk March 20, 2022 edited
lookupObject.Email works fine. I can see all email address in log as expected.
but {{lookupObjects.Email.substringBefore("@")}} is empty :(
Krzysztof
Krzysztof Hotiuk March 22, 2022
Hi there,
Any other suggestions / ideas ? :)
Krzysztof
Jennifer Luo
Hey Krzysztof,
You can try {{lookupObjects.Email.split("@").first}}
