Insight - Problème d'import
Arnaud LESUEUR
November 17, 2022
Bonjour,
Dans insight quand je vais dans la configuration du schéma d'objet dans l'historique des importation toute les lignes sont en erreur quand je vais dans le détails d'un d'entre eux j'ai les messages suivants :
5 erreur(s) découverte(s) dans les données source
  • Error: Transaction silently rolled back because it has been marked as rollback-only. [Object (Label: 2022-11-17_10:03, Id: 333,245)].
  • Error: Transaction silently rolled back because it has been marked as rollback-only. [Object (Label: 2022-11-16_15:11, Id: 331,911)].
  • Error: Transaction silently rolled back because it has been marked as rollback-only. [Object (Label: 2022-11-17_11:32, Id: 333,617)].
  • Error: Transaction silently rolled back because it has been marked as rollback-only. [Object (Label: 2022-11-16_11:01, Id: 330,520)].
  • Error: Transaction silently rolled back because it has been marked as rollback-only. [Object (Label: 2022-11-17_12:36, Id: 333,999)].
