I dont' want to use any add-ons. Just wanted to user salesforce rest api for integration.
Community moderators have prevented the ability to post new answers.
Hy Sam, I believe you won't be able to do the rest calls without a connector.
The reason why is explained here in this old topic:
Rodrigo Silva
found best tool for me
For me this is the ans.
Sam,
While it perhaps might be possible to cobble something together without add-ons, the fun of working through getting RID of "no add-ons" stuff from predecessors is showing me the beauty of plugins in this environment.
If you build something and make it work, you become responsible for KEEPING it working through API changes as the versions migrate. If you do it with plugins then it becomes a SEP (Somebody Else's Problem) as the vendor then is keeping up with it and you just keep stuff updated.
The alternative is you could be stuck on a version of JIRA for as long as it takes to update anything you cook up even if it happens to be <gasp> a buggy version.
My $0.02 worth
mike
AS Rodrigo mentioned you need something. We use the Go-to Group CRM plugin for our SFDC integration into JIra.
Get Certified! ✍️Online forums and learning are now in one easy-to-use experience.
