I have written above posting, researched and tried, but could not get anything from Jira. I assume that it's clear on my end. So I want to make sure the suppression list is clear for us. My team is only 5 users so far... upgrading to standard to get a support ticket is too much to get an invitation for now. Is there any chance to get a ticket without upgrading to standard?
Thanks in advance.
Hi @Gangmin Lee ,
I've checked our suppression list and found some users on your domain. The error message our mail service received was the 550 5.4.1 "recipient address rejected: access denied" error covered in this article . I would recommend following those steps in Office 365 to ensure future emails don't bounce back to the Atlassian mail service.
The suppressions for email addresses on your domain have been cleared, and if you re-send the invitations, they should go through this time.
Daniel
Hi @Gangmin Lee
I will suggest checking the following:
If the above are true and you cannot find the email filtered out then unfortunately, you’ll need Atlassian for this.
As we have no access to logs, it is near impossible to figure out what exactly is going on.
HI, Ismael Jimoh
Appreciate for your answer.
1. Yes all our team is working with email internally and externally so far.
2. As I know our email system works great with Office365. The problem is only one member. All the other members got their invitation and are using very well.
Hope it's right answer for you.
if the issue is for a single user then I’ll suggest the following.
I believe the user should normally then be able to get the necessary access.
Just stuck from the first. I can see the message "To complete setup and log in, click the verification link in the email we’ve sent to ***@***.com", though, still nothing in the inbox, junk or spam...
Thanks for the reply anyway.
