Is 'Advanced Roadmaps' only available in Jira Cloud? Is it available in Jira Server?
If it is available in Jira Server, will that version allow for tracking a hierarchy like - Theme -> Initiative -> Epic -> Story -> Sub-task, with the ability to roll %Complete all the way up to Theme and show this graphically?
Standard Roadmap is only available in Jira Cloud
Advanced Roadmaps is included in Jira Cloud Premium and Jira Data Center without the need to install it separately.
For Jira Server, if you already have an Advanced Roadmaps Plugin License for Server, then you can continue using it and you have 2 options:
1- Continue using your existing Jira Server product and the plugin
2- Upgrade your Jira Server product to newer versions ( >=8.15) and use the bundled version of Advanced Roadmaps (no need to install the plugin separately). The bundled version has all the new features.
If you don't have an Advanced Roadmaps Plugin License for the Server, then you cannot buy it anymore and need to upgrade your license to Data Center.
For your second question:
Yes, in Advanced Roadmaps you can define a customized issue-level hierarchy and the progress is rolled all the way up.
assuming you have no license for 'Advance Roadmaps' as of today then...
Doesn't that mean it is not available on Jira Server, if I have to upgrade?
you are right - you would need to change to Jira Software Data Center first. There is no opportunity since last February anymore to get a new license for 'Advance Roadmaps' on Jira Server.
It is better explained on this page:
https://www.atlassian.com/software/jira/features/roadmaps
The basic roadmap is only available in Jira Software Cloud. Advanced Roadmaps is now part of Jira Software Data Center. Previously Advanced Roadmaps was available as a standalone app for Data Center but as of February 2, 2021, it is included with your subscription to Jira Software Data Center.
Daniel
Is 'Roadmap', 'not Advanced Roadmap" standard with Jira Software Server or do you need a plug-in in Jira Software Server?
In Jira Software Server there is no Roadmap in that sense built-in.
@Devin Griffin yes it's available on Jira Server, however, you'll have to update to Jira Software Data Center 8.15.
Is that to say I need to upgrade to Jira Data Center? Doesn't that mean it is not available on Jira Server, if I have to upgrade?
Please clarify.
Learn more
