Can a template e added automatically in Description and environment fields? For manually created bugs it would save up a lot of time. I want Jira to automatically add in bug description field lines like 'Steps', 'Preconditions', 'Expected result', 'Actual result'
In environment field I want Jira to add lines like 'Devices', Browser version', 'Accounts'etc.
Hi Ginta - Welcome to the Atlassian Community!
If I understand you correctly, you want to place new text in the description field when a bug is created?
You should be able to do that with Automation For Jira. Here is some more information to get you started:
There are two types of automation:
Automation Basics: https://www.atlassian.com/software/jira/guides/expand-jira/automation
You can do this via global rules to apply to all projects also. You'll need to be a Jira Admin/Site Admin, go to Jira Settings > System > Automation Rules (left-hand menu).
For more on using Automation For Jira see these help pages.
I don't have an "Automation Rules" option. I tried the post function, option, but that did not let me add in line breaks and over-writes the description entered on the Create screen.
You can use Description Templates for Jira Cloud in your Jira instance
Register now
