Sign up Log in
Is it possible to check if a Test is linked to a Test Execution or any other issue?
Megha Debnath
I am looking for a way to find out if there is a way to check if a Test is linked to or is present under any Test Execution, Sub Test Execution, etc. I have tried using TestRun Lists but it is returning more than 1000 issues hence unable to check the results. If anyone can suggest any way to find out the linked issues it would be very helpful.
Thanks in Advance!
Megha Debnath
Sandeep Nair May 24, 2022
When you open a test in Jira, you can see a set of buttons from Xray under "Test details". If you click on the "Test runs" button, you can see all the linked test executions to that test.
Upcoming Jira Events
