×Hello community :-)
I'd like to clone epics (and maybe tasks, issues etc.) from a scrum (or, later, a business) project to a next gen project, because I'd like to build a road map there. While trying that, two main problems occured:
Does anyone have a suggestion or solution for one or both problems? I'm especially interested in the latter part. So is it possible to clone - probably by automation - epics that are updated automatically when edited in one project (without editing in the second)?
Thanks in advance for your help,
Sebastian
Hi @Sebastian Mühleis ,
With our Jira cloud app Deep Clone for Jira you can (bulk) clone between classic and next-gen projects.
It's also possible to edit the cloned issues while cloning.
Maybe that could solve your problem?
Hello Marlene,
thanks for your quick response - I already replied yesterday, but it seems the system didn't like my answer to yours :-D
I'll definitely try out the app at a later stage of the setup of my Jira & Confluence environment, but right now we're only using the free plan and want to use free apps and plugins (since it's only a pilot atm).
I am happy to hear, that you plan to try out Deep Clone for Jira, @Sebastian Mühleis !
If you want to have a preview you can download the free trial and use the full feature set of the app for 30 days without paying for it.
Hi Sebastian, I don’t know if this is going to be possible because of the differences between classic and NexGen. However I would definitely try using project automation to make this happen. You might use a scheduled trigger for this if your classic epics already exist and add a label to the ones you wish to clone, leveraging the label as a condition. Start small with a test epic so as not to create a mess you have to clean up.
Hi Jack,
thanks for your quick reply. I'll try this one out and give you/us all a feedback, if it did work out or not.
Hello again Jack,
the cloning of the epic(s) worked out fine via automation, but I'm still experiencing problems with the updating. I'll post a new topic with screenshots of my automation rules and audit messages soon.
