Is it possible to create an Issue without a project?
Hector Guerra October 4, 2019
My understanding is that the project field is mandatory as it is the base of the hierarchy, but just got a request to create an issue without assigning it to a project.
When I create a new issue, the project drop down has an item selected by default.
Is it possible to make the project field optional and ignore it?
Thanks in advance for the support.
3 accepted
Onder Ozcan
Hi Hector,
An issue can represent various things and it depends on the context.
For instance, an issue can represent a bug in a mobile app project whilst in a help desk project it might mean a support ticket.
An issue must belong to a project. You can double-check with create issue screen i.e project is mandatory. Hope this helps.
Kind Regards,
Onder
Hi Onder,
Thanks for the clarification.
This is really helpful.
Hector
John Funk
Hi Hector - Welcome to the Atlassian Community!
No, it is not possible to create an issue without a Project. You could create an "Unassigned Project" project and have issues created there. Then you can do a move to the appropriate Project later.
Hi John,
Thanks for the quick reply.
That makes sense and it is very helpful.
Hector
Gikku
Hi @Hector Guerra
No, it is not possible. An issue has to belong to any of the project for it to inherit all the configuration features - issue type, workflow statuses, permissions ..etc
Great to confirm it is part of the default hierarchy and mandatory.
Thanks Gikku,
Hector
Like Gikku likes this
