Is it possible to extend the strip view of attachments?
Philipp Rosenboom December 6, 2022 edited
We have migrated from an older Jira Server version to the Jira Cloud now and are facing a problem with your attachment section on the items: The "strip view" is limited to one line only. This is different to the older Server version, as here the section reacts on the amount of attachments by getting bigger if needed.
So my question is: Is there any way to extend the strip view to multiple rows (dynamically or fix) to show more attachments at one?
Dave Mathijs
Hi @Philipp Rosenboom , no, that's not possible. Don't hesitate to submit that feature suggestion with Atlassian Support.
Owen Wallis
December 18, 2022
You're able to change from the strip view to a table view.
The table view allows you to see many more attachments.
Let's build A Rovo Agent 🤖
Save your spot
