I've found a gadget called "JIRA-Roadmap" where I am able to select "All projects" but this gadget isn't showing anything.
That gadget displays version, do you have any in those projects? Here is the Atlassian description for that gadget (server version but should be the same):
The Road Map gadget shows versions which are due for release within a specified period of time, and a summary of progress made towards completing the issues in those versions.
Try adding versions and issues with those versions, and let us know if you see something.
Regards
Thanks. Adding versions and issues solved the problem.
Is it also possible to get a "graphical" view like the one in the project roadmap?
I don't think you can get the graphical view like in the project roadmap. For that, I guess you'd need a commercial third-party app. We have a commercial app to create dashboards, Ronin Dashboards for Jira, but we haven't implemented (yet) a roadmap gadget...
