Meaning create/configure multiple sub-task issue types therefore available from parent issue types to be created as a child ticket?
Hi Angela,
Short answer is yes!
Jira supports creating new issue types as "Standard" issue types or "Subtask" types which can be added to a parent using the "Create Sub Task" menu item. Both can be created the same way:
Hope this helps!
Cheers
Great! Feel free to accept the answer so that other can benefit from your question and its solution :)
Have a great day and weekend!
Still thinking about joining us for Team '25 Europe? Early bird has been extended for just one week! Now’s the time to lock in your lowest rate. Use code TEU25COMM-20 to save 20% at checkout. Hurry, this only lasts for 1 more week.
Learn more
