Is it possible to link Confluence page automatically?
Deniz Yalçıntepe
Hi community,
We use Jira Software Cloud. Single select custom field is on create screen. And there should be link Confluence page based on this custom field. I looked up for automation. But I couldn't find a way.
Bests,
Deniz.
Jan Šimek
March 8, 2023
Hi @Deniz Yalçıntepe ,
I hope it will help your needs. If you know exact custom field and what exact link there should be used it should work without a problem?automation link.png
What about this kind of automation?
Deniz Yalçıntepe
Hi @Jan Šimek ,
Yes, I know exact custom field and exact link. This will look like different than link Confluence page on Jira issue.
Thank you for the suggestion. This may be the only way.
Like Jan Šimek likes this
Zubeyir Ozay
March 25, 2023
@Deniz Yalçıntepe I wanted to create the same issue, however, there is no option to link a created confluence page in jira "Link confluence page"
Deniz Yalçıntepe
Hi @Zubeyir Ozay ,
Do you mean there is no "Link confluence page" action for automation?
