Sign up Log in
Is it possible to migrate Next-Gen Projects or Team managed projects from one cloud instance to othr
prashantgera April 27, 2021
I am looking for a solution to migrate the Next-Gen project or Team-managed project from one cloud instance to another. Please let me know if there is a way out.
I am able to migrate Classic projects or Company-managed-projects
Walter Buggenhout
April 27, 2021
Hi @prashantgera,
As of now, migration of next gen projects between cloud sites is not yet supported 1-1. In This support article currently available strategies and workarounds are listed.
Maybe it is interesting to know that Atlassian is currently working on a migration assistant to facilitate cloud to cloud migrations. I cannot tell you whether next-gen migrations will be part of that first release, but it is definitely worth to keep an eye on. See this feature request to track progress: JRACLOUD-72570
Hope this helps!
prashantgera April 30, 2021
Hi @Walter Buggenhout
Thank you. With the workaround available, I am able to move projects between two instances but the Sprint field doesn't move. I understand that we don't have Sprint id in the new instance. But is there a way to do it?
Thanks in Advance
Regards
Prashant Gera
Prince Nyeche
April 27, 2021
This would be a nice feature to have. CSV should just do the most minimal migration for you. Although there are little things that won't get moved over.
Hi @Prince Nyeche
Thanks for your reply. By little things, you mean the "Sprint" field?
Is there a way to do it?
Thanks in Advance
Regards
Prashant Gera
