Hi All,
I have a popup screen and want to know if performing esign on this screen is possible.
Best regards,
Amit
I have to second Alex here.
Out of the box it's not possible. In the past we've used this app (https://marketplace.atlassian.com/apps/1211601/electronic-signatures?hosting=cloud&tab=overview) to do this.
When transitioning you add the (new) custom fields to the screen and it will block you from transitioning unless you sign it (for use we used AD credentials on DC).
All signatures are then tracked and traced.
There are many apps out there doing the same so I suggest to install one or a couple in trial and see which one fits you best. But either way you'll have to use an app for it.
Hi @amit_bakst
Out of the box you can't. So you have two options imo:
