Is it possible to populate description field via automation, including an hyperlink
Tiago Pereira
September 8, 2023 edited
2.png I tried already multiple ways to insert an hyperlink on a description automated population, but it doesn't work:
<https:https://docs.google.com/presentation/d/11vImbErkNUCOnjtHKcpHrmSsA-3BwKzm87M_nSw8ypo/edit#slide=id.g25b57b7e213_0_0
| 1pager>
[1pager"|https://docs.google.com/presentation/d/11vImbErkNUCOnjtHKcpHrmSsA-3BwKzm87M_nSw8ypo/edit#slide=id.g25b57b7e213_0_0
Is this possible?
3 votes
Sayed Bares _ServiceRocket_
@Tiago Pereira to add a link to description, you'd just need to use the following syntax:
[<link name>|<URL>]
so you may add:
[1pager|https://docs.google.com/presentation/d/11vImbErkNUCOnjtHKcpHrmSsA-3BwKzm87M_nSw8ypo/edit#slide=id.g25b57b7e213_0_0 ]
Tiago Pereira
it worked thanks :)
