Sign up Log in
Is it possible to track all meeting Plan of Actions in Jira
deepa.jayaram May 5, 2022
Hello Everyone,
I am new to JIRA and just started to learn the concepts. It would be helpful to know the answer to my query
"Is it possible to track all Meeting POAs in the JIRA Software tool"
Dave Mathijs
May 5, 2022
Hi @deepa.jayaram ,
Are you using Confluence as well or not?
In Jira Cloud, you can create a simple task management project in Jira Work Management
Just create a task for each meeting point of action.
Give it a try.
No, we don't use Confluence.
Thanks, Dave.
Will try for sure
deepa.jayaram July 5, 2022
@Dave Mathijs - Is there any specific reason for you to suggest Jira work management instead of Jira Software for tracking POAs?
It is possible to track POAs in Jira Software by creating separate projects.
Dave Mathijs
July 7, 2022
Sure you can Jira Software but it's a bit overkill in my opinion when simply tracking POA's. No need for separate projects though. You can create custom fields for categorisation or any kind of structure.
Have a look at this article: Use Jira Work Management for task management
deepa.jayaram July 13, 2022
Thanks @Dave Mathijs
