Documentation claims that only issue.components.name is available and also lists interface could be used.
Is it possible to extract lead users from components?
My intention is to send a slack message to component lead when an issue is created with specific component defined.
you can also call the Jira API to get the component lead (documentation). I found this tutorial quite helpful to follow, which makes it quite easily.
I think you should get the component lead accountId then via the webhook response like this:
{{webhookResponse.body.lead.accountId}}
And you can upvote the feature request in the meanwhile: https://jira.atlassian.com/browse/JRACLOUD-76851
Regards
Jan
Hello @Production Management ,
The Component lead as a smart value is still on the backlog and not yet implemented for Automation for Jira, however, there is a really good discussion on a workaround in the following thread noting a method to set a custom user picker field on an issue with the component lead, then referencing the custom field for follow up automation actions:
Earl
Hi @Jan Schneider Thanks for your guidance on getting the component lead from the API. I'm hoping you could help me a bit more.
I know I can get the component information (name and ID) from: {baseurl}/rest/api/2/issue/{issuekey}
But, is there a way to get the component lead directly from the issuekey to use the webhook response you've shared?
My use case is to get an issue's components and add the component leads as watchers on the issue. Using the notification scheme to add component leads does not suffice as this is not queryable.
Thanks in advance!
