Is it possible to use multiple filters for single gadget?
Narendra Kumar
Hi, I want to have result of multiple filters on single gadget. Please help me to know that is it possible to do or not? Thanks!
2 accepted
Jack Brickey
You can certainly combine two filters into one and use this new combined filter.
e.g. Filter in (filter1, filter2)
Narendra Kumar
Thank you @Jack Brickey .
Saransh Gupta
February 25, 2022
This is not working for me in the pie chart gadget.
(test1,test2)
It is only allowing me to add one filter.
Zita Bagi
March 3, 2022 edited
You should save a filter which has this JQL:
not only
(filter1, filter2)
 So filter3 is "Filter in (filter1, filter2)" and then you put filter3 in the gadget
KE
Let's say - I have two filters below
type = defects and status != closed and assignee = ABC
type = defects and status != closed and assignee = XYZ
How can I combine the two filters above into one combined filer?
Like • Chaithra C likes this
Jack Brickey
@KE , are you asking for this...
type = defects and status != closed and assignee In (ABC,XYZ)
KE
Appreciate the response, Jack.
I'm trying to understand how can I use two different filters and save it as a combined filter so I can input that into a gadget (dashboard)
Jack Brickey
Then do just that...
Filter1: type = defects and status != closed and assignee = ABC
Filter2: type = defects and status != closed and assignee = XYZ
Filter3: filter in (Filter1, Filter2)
Then you can reference filter3 for example in a dashboard gadget, and it will include all issues defined by filter1 and filter2. maybe I'm still missing your point?
KE
how do I name my filter as filter 1 and filter 2?
the below query populates with error message:
filter1 as (type = defects and status != closed and assignee = ABC)
Error in the JQL Query: Expecting operator but got 'type'. The valid operators are '=', '!=', '<', '>', '<=', '>=', '~', '!~', 'IN', 'NOT IN', 'IS' and 'IS NOT'. (line 1, character 10)
Jack Brickey
You create and save filters in the Advanced issue search. Click into the search bar in the menu and select Advanced issue search. From there you can create and save/name the filter.
KE
Thank you so much, Jack. This helped me with the solution I was looking for. :)
Like • Jack Brickey likes this
Zita Bagi
December 20, 2019
Hi, are you referring to the Filter Result gadget? These can only who the result of 1 filter, but you can add multiply filter result gadgets to display as many results separately as you want.
Narendra Kumar
Thanks,  Z B for your response. Yes, I'm referring to the Filter Result gadget. Could you please tell about list of gadgets or some name of gadgets which supports multiple gadget results ?
Zita Bagi
December 20, 2019
Generally, if you click on Add gadget in the top right corner of the Dashboard, click Load all gadgets, and you can select from them.
There is no version of the Filter result gadget which would display multiply filters.
If you would like to list the filters themselves, you can add the Favourite Filters gadget.
However, there is a free plugin which can display filters based on what you want to be displayed:
https://marketplace.atlassian.com/apps/1214394/menu-gadget?hosting=server&tab=overview
Then if you click on the filters, you are directed to an issue search page where you can see the results.
Like • Narendra Kumar likes this
Narendra Kumar
Thanks Z B
Deleted user December 5, 2023 edited
How many filters I can use in one search query?
