Is it possible to view multiple projects without switching from Releases view?
Matthew Lewis May 13, 2020
We use a calendar date as our Release Version. This same version is used on multiple Jira projects (about 3-4).
So for instance, if we look at the URL:
us.atlassian.net/projects/{ProjectKey}/versions/{VersionKey}/tab/release-report-all-issues
Problem: We can pick a different project, but it takes us all they way up to the default project view (I think which is the RapidBoard/Backlog view). It would be ideal if the Release view could be "pinned" so that the user doesn't have to navigate back to it for each project.
This is the object we'd like to be able to to switch on, rather that the top project level.
<a data-testid="NavigationItem" id="releases" text="Releases" legacyid="com.atlassian.jira.jira-projects-plugin:release-page" index="0" customcomponents="[object Object]" spacing="default" class="css-t3yiul" href="/projects/ALPHA?selectedItem=com.atlassian.jira.jira-projects-plugin:release-page" target="_self"><div class="css-mvkep6"><span class="Icon__IconWrapper-dyhwwi-0 bcqBjl"><svg width="24" height="24" viewBox="0 0 24 24" focusable="false" role="presentation"><g fill="currentColor" fill-rule="evenodd"><path d="M6 12h8v-2H6v2zM4 8.99C4 8.445 4.456 8 5.002 8h9.996C15.55 8 16 8.451 16 8.99V14H4V8.99z" fill-rule="nonzero"></path><path d="M6 7.005C6 5.898 6.898 5 7.998 5h2.004C11.106 5 12 5.894 12 7.005V10H6V7.005zm4 0V7H7.999c.005 0 .002.003.002.005V8h2v-.995z"></path><path d="M4.5 17h13.994l1.002-3H4.14l.36 3zm-2.495-4.012A.862.862 0 0 1 2.883 12h18.393c.55 0 .857.417.681.944l-1.707 5.112c-.174.521-.758.944-1.315.944H3.725a1.149 1.149 0 0 1-1.118-.988l-.602-5.024z" fill-rule="nonzero"></path></g></svg></span></div><div class="css-t44v0r"><div class="css-1h2b0g4">Releases</div></div></a>
Steps:
1. I've looked through most of the project settings I have access go but nothing controlling the nav pane or releases specifically.
2. I know there are plugins in the marketplace to deploy releases or update them in multiple projects at a time, but we simply want to have the view behavior change through the navigation pane. (It's probably not worth a whole paid add-on just for this feature.)
Is this possible in the native environment or is there something else that can do this?
