Is there a Kanban view in a Bug Tracking project?
Dario Piantanida February 11, 2022
I set up a Bug Tracking project and I would like to see my issues in a Kanban view, like Trello. Is this possible and how?
Mikael Sandberg
Hi @Dario Piantanida,
Yes, you can create a Kanban board in a Bug tracking project. All you have to do is create a new board and select it to be a Kanban. As long as the project is a Software project you have the option to create either a Scrum board and/or a Kanban board.
Hello @Mikael Sandberg
can you guide me in creating this new board?
Do you mean a dashboard?
Thank you!
Mikael Sandberg
All you have to do is click on the dropdown arrow when you are in the project and select Create board, then just follow the onscreen instructions.
Also check out Learn kanban with Jira software
Dario Piantanida February 14, 2022
Thank you, all done!
Like • Mikael Sandberg likes this
symeonidisfx March 4, 2022
"All you have to do is click on the dropdown arrow when you are in the project"
where exactly is this option? I cannot find the dropdown
can you have more than one board per project ?
Like • Ricardo Hassan likes this
