I have a filter that shows Daily Status Updates but I want to further add a column to show WHO (which user) has last updated the Jira issue.
I cannot use issuekeyIN updatedBy("") as it only works for a specific user. but i want to show all users who have last updated on an issue.
It's disappointing this column is not added by default. The information is there in the ticket history'. It should be easy to pull without all the workarounds 😢
Thank you everyone for your help by the way.
I couldn't agree more with this. It's the most natural thing in the world to need to see who updated the issue and for performance reasons it's super aggravating to have to make an additional rest call to get this from history.
Agree.
my suggested solution of using Automation is sound if on premium but not so much standard now given automation rule caps on standard.
I understand you want to see the user who last updated as issue in a filter view. Unfortunately I don't think this is easily possible. You might be able to use Jira Automation to read the user from the issue's history, and store it into a custom field.
Alternatively, if you are open to solutions from the Atlassian Marketplace, this would be easy to do using the app that my team and I are working on, JXL for Jira.
JXL is a full-fledged spreadsheet/table view for your issues that allows viewing, inline-editing, sorting, and filtering by all your issue fields, much like you’d do in e.g. Excel or Google Sheets. It also comes with a number of so-called smart columns that aren’t natively available, including last updated by user. This is how it looks in action:
As you can see above, you can easily sort and filter by last updated by user, and also use it across JXL's advanced features, such as support for (configurable) issue hierarchies, issue grouping by any issue field(s), sum-ups, or conditional formatting.
Best,
Hannes
Hi @Hira Ahmed Shaikh , You are correct that the updatedby function only allows for a specific user parameter. If you're looking to record who made the latest update you could consider creating an automation rule in conjunction with a custom field.
trigger - issue updated
action - edit issue and set the custom field to the user who triggered the rule
Just came looking for this as well. When I view my tickets, I need to be able to easily tell if I was the last one to update my ticket or if someone else has updated it so I can go see their updates. Was a simple solution to this ever found?
Also, is there a Feature Request system anywhere for Jira that we can all go Up-Vote something and then hope that someday they might actually add this basic feature?
Maybe some of the following options can help.
1. If you want to check updaters for a single issue, you might do it with the help of History in the Activity section. You will see the last person who updated the issue.
2. Activity Stream Gadget on Jira Dashboard.
3. If you want to have the ability to add/remove any column based on issue fields (e.g., Updated by), check out Issue History for Jira app. My team developed it as a customizable report for daily team activities.
Get your free all-access digital pass and don’t miss groundbreaking announcements, brand new features and product updates, insight-packed sessions, and exclusive digital content.
Sign up
