Hi!
I'm looking for a permission to limit the access to the reports or a specific report in Jira cloud (e.g. the Burndown Chart, Sprint Report, etc.).
Is there a chance to give this permission such as fine-grained?
Thanks for your help.
Patrick
No, the visibility options are for issues, there's nothing stopping people using a report.
There's not a lot of point - if they can see the issues, they can work out the report from that anyway. And if you take the reporting away and they try to get something a report would tell them, you'll find they often get it wrong and then act on bad information. It's far better to let them have an accurate report.
Thanks for your fast answer.
Yeah - I see it for the default reports. I've the requirement to restrict the read access to xray testing reports.
I thought if there is a chance to permit default reports then is implicitly my original question solved :-)
But I see, unfortunately, this isn't possible.
Thanks.
Register today
