Is there a possibility to hide the 'child issues' of being display on Kanban board?
Lucas Ferreira August 17, 2022
Hey everyone!
I've been struggling to try to find some kind of option to hide the 'child issues' instead of being piled under the 'mother task' on a Kanban board of a company-managed project. (Example attached below)Exmaple Company Managed.PNG
I would like the same visualization we have on a Team-managed project, where the card only informs me that it has child issues, but doesn't pile them below itself.
Does anyone know if that's even possible?
*Note: I prefer using the kanban company managed because of the option it gives me of separating the backlog from the board, like on a scrum template and the team managed doesn't allow me to do that.
4 accepted
Nic Brough -Adaptavist-
August 17, 2022
You'll need the sub-tasks on the board in order to close them, but you can use a quick filter to hide them when you don't need to see them.
The best filter (because it doesn't matter if people add more sub-task types) is
issuetype not in subtasktypes()
If you're going to work with them off-board, then you can add that to your board filter.  If you do that, make sure you rig your workflow to stop people from closing stories with open sub-tasks.
Thanks very much!
@Nic Brough -Adaptavist- , @Trudy Claspill , @Samuel Gatica _ServiceRocket_ thanks for the help, I successfully added the filter and it did exactly what I needed, however on team managed there is an 'icon' on the cards (same image as previously attached) that shows that specifically card has 'child issues', do you know if is that a thing we can enable on company managed as well?
Trudy Claspill
August 17, 2022
Another option to consider is modifying the Sub-filter of your Kanban board to hide the sub-tasks. The Reports will be based on the primary Filter Query of the board, so sub-tasks would be included in those (where appropriate), but the Sub-filter allows you to reduce the clutter on the board without modifying the primary Filter Query or having to use Quick Filters.
August 17, 2022
Thanks very much!!!
