Is there a way for automation to set Test Issue Status to Done when Execution = Pass
Misty Meyers
Happy Friday!
I am searching for a way to eliminate the manual step of transitioning a Zephyr Test Case to "Done" when the Test Execution Status is set to Pass?
If seems there are very few links in the Automation tools in Jira that pull in Test fields such as Execution Status.
Thank you for your help!
June 4, 2021
Hi @Misty Meyers  Happy Friday!
There are a few open suggestions to add more support to automation for tools like Zephyr, such as this one: https://codebarrel.atlassian.net/browse/AUT-1295
Until stuff like that is added, two suggestions I have are:
Best regards,
Ihab Palamino
November 10, 2023
hello guys i have a question is it possible to execute tests in jira where i use xray in an automatic way if yes could you provide me how?
November 10, 2023
Hi @Ihab Palamino -- Welcome to the Atlassian Community!
Please check if Xray has a REST API function which allows executing the tests.  If so, that could be called from an automation rule using the Send Web Request action.
