Is there a way to backup Advanced Roadmap settings including:
- Views (View settings)
- Data inputs
- Fields
Jus wanna anticipate the worst-case scenario of someone messing around w/ the views.
Hi Stephen, you can’t backup just the roadmap config. You can perform a complete backup of your instance.
OK so AR configuration is part of the back of the instance, right?
Register now
