Is there a way to be alerted when anyone moves an item out of the current sprint?
Lily Tucker-Ha January 12, 2023
please can someone help; Is there a way to be alerted when anyone moves an item out of the current sprint?
I've been trying to set this up myself for a while but I'm getting stuck because I'm using the "Value changes for" trigger; i.e.
Trigger: "when value changes for Sprint"
Branch: for issues in the sprint
Then: Send email
However, the rule fails to run with the error :
Action details:
["10099"]
Branch rule / related issues
Can't branch rule as it requires a sprint in the context for this option. More than likely you have a trigger that isn't sprint related.
Which makes me think I'm not using the correct trigger, but there isn't one I can see that is relevant. At the same time, I know you can't use "current" or "active" sprint on filters, so maybe that's why I can't specify changes to the active/current sprint?
Maybe there's an easier way to do this other than automation that I'm missing completely. Please help?
Lily
Mark Segall
Hi @Lily Tucker-Ha - The big thing is that you need to be able to evaluate whether the original or new sprint value was for the current sprint.  Try something like this:
  • TRIGGER: Field Value Changed (Sprint)
  • ACTION: Lookup Issues
    We'll first make sure that the issue hasn't been pulled into sprint (unless you want that captured too)
    • sprint in openSprints() AND key = {{Issue}}
  • CONDITION (Advanced)
    • {{lookupIssues.size}}
      Not Equals
      1
    Now we'll figure out the current sprint
    • {{fieldChange.from}}
      Equals
      {{lookupIssues.first.sprint.id}}
  • ACTION: Send Email
Hi @Mark Segall wow thank you, I may or may not have followed the logic, so thank you for laying it out so simply for me. This worked a treat!
Like Mark Segall likes this
