Is there a way to create a folder in sharepoint when issue created in JIRA
Rita Saad YOUNES January 30, 2024
I want to create a folder in sharepoint when a jira issues created for a specific project.
Is it feasible in JIRA automation?
Alex Mendes_ikuTeam_ February 20, 2024
Hi @Rita Saad YOUNES ,
Thank you for using Team Files. I was about to reply your post when I noticed you are already using it ;)
Here is a blog post showing the automation feature in Team Files for Jira: https://www.teamfiles.app/blog/use-case-4.html
If you need any help, just let me know.
Alex
January 30, 2024
Do you have a REST API function in SharePoint to call to create the folder?
If so, your rule could call the function using the Send web request action, as described in this how-to article: https://community.atlassian.com/t5/Jira-Software-articles/Automation-for-Jira-Send-web-request-using-Jira-REST-API/ba-p/1443828
Rita Saad YOUNES February 19, 2024
Hello @Bill Sheboy I used the add-on called Team files that have a feature of create automatique folder in Sharepoint
February 19, 2024
I am not using the addon Team Files and am not familiar with it.
You may want to contact the vendor's support team, or check their documentation, through their marketplace page.
Read the story
