Would it be possible to look at all the data from the scrum teams at my org in aggregate? Specifically looking if there is something I could download in a CSV form. For example, all the charts for burndown and velocity. There is a data table behind the UI, and I'm wondering if it is possible to extract that raw data.
You can try the Export from the issue Navigator. There is even the possibility for CSV Form. Just try it Out.
