Is there a way to make fields display for all users on "Create"?
Erin Mihalik
Recently we updated the screen and field config for a Create on a specific project.  Is there a way for the Create form to automatically show the new configuration?
Currently, it seems that each user would need to follow these steps:
  1. Click Create (+)
  2. Click Configure fields (in top right corner)
  3. Select all fields
Once they do that then the form will always show correctly.
I am looking for a way for them to not need to do that.  Is it possible?  I could make them required fields so they cannot create, but most have a default value so that won't be ideal.
Jessica Schmor November 2, 2023
Has this been resolved? I am having the same issue.
Michael Chekal
November 3, 2023
Sorry, no replies at all until yours. Let me know if you find an answer.
Jessica Schmor November 3, 2023
The only thing that I have found is to show each individual user how to set to "all field" instead of custom from the create screen. It is a bit annoying because the education is time-consuming and peeps don't remember if it is turned off.
