  • Community
  • Q&A
  • Jira
  • Questions
  • Is there a way to see the Filter ID (number) of a created Jira Filter w/o looking at the Filter?
Scott Buratt
(Jira Cloud)
When I reference a filter from within a filter, I use "filter in (xxxx)"
This means I need to know what the value of filter "xxxx" is.
With that, is there a way to present the filter ID w/o having to look at each filter link?
Luis Machado
November 7, 2022
Hi @Scott Buratt ,
You should be able to leverage the filter name instead of the ID with quotations around it if there are spaces in the name.
filter in ("Name of Filter")
This may become difficult if you have filters with duplicate names though. The JQL field should also give you auto-complete suggestions so if you have duplicates you could work your way down the suggestion list.
Scott Buratt
Thanks @Luis Machado !
Like Luis Machado likes this
