Is there a way to use the Links Hierarchy plugin to export multiple hierarchies?
David Grierson
When using the Links Hierarchy plugin to view an issue you can use the Export (Current fields) function to generate an Excel spreadsheet containing a hierarchy of the issues related to the current issue.
Is there a way to generate the same report but for multiple root issues?
export.PNG I can't seem to find anything in the documentation - can anyone advise?
David.
Pablo Beltran
May 8, 2017 edited
Not unless a new issue root is created and link them to the new root...
David Grierson
Ah - so I could use a Top-level issue and then relate these "child" issues to that in order to describe a relationship between these so that they are all potentially displayed on the same hierarchy?
That might work for our users.
