Is there any possible in jira software to get the approval button in email without any plugins?
Haroon Rasheed May 7, 2022
Set all Automation part in Jira but need to change the transition manually whether any possibility to get a approval or reject in mail where it will change the transition in Jira software.
Fabio Racobaldo _Herzum_
Haroon Rasheed May 8, 2022
Hi @Fabio Racobaldo _Herzum_
We don't have Jira Service Management we got only Jira Software where I can't find any approval options
Jack Brickey
You could use Automation if the email response indicated “approved”. You could search last comment for Contains approved.
Thanks I will test it out
Jack Brickey
I will note that while you could make this work it is only as reliable as your ability to get the approver to reply with very specific words. For example you would want to direct the response to be "approved" or "rejected". This would allow the automation to be reliable. You might consider other email handlers and see if the provide a better option if that is possible.
