Time in Status for Jira Cloud by SaaSJet can improve your reporting and metric.
This plugin automatically brings information that you need:
1. The time in status for each phase in a workflow
2. A number of times an issue has been in each status and went from status to status.
Also, this app generates other reports: average time in status, assignee time to each issue, time in status per date and status entrance date.
Moreover, there are features that allow you to export data and view all reports as charts.
You can get more information and download the add-on at the Atlassian Marketplace.
Mayur
Thank you for recommending our program. We are very pleased that it is useful for you.
Hi @kavita.desai welcome to the Atlassian Community!
You can view all reports in three views: table, chart, and pivot table.
Try how it works in the demo version without installing the app.
Hope you find this add-on helpful.
Regard
Hi @kavita.desai,
If you do not mind using a 3rd party app, you can analyze issue workflow with eazyBI for Jira.
Out of the box, eazyBI offers a set of different metrics to analyze status change history (data from issue history tab), how many times, when, for how long, and who made a status change (see picture below).
You may also check the eazyBI Demo account for more reporting ideas to analyze issue status history or lead and cycle times:
https://eazybi.com/accounts/1000/dashboards/7513-age-lead-and-cycle-time
Best,
Zane / support@eazyBI.com
Hi @kavita.desai ,
Unfortunately, what you are looking for is not possible with the built-in functionalities of JQL. Because JQL can not make calculations and you need status time to be calculated
For this exact need we developed Status Time Jira app. It provides reports on how much time passed in each status. By grouping statuses you can get resolution time(E.g from new status to done status). You can also export the report as CSV and open it in excel.
Once you enter your working calendar into the app, it takes your working schedule into account too. That is, "In Progress" time of an issue opened on Friday at 5 PM and closed on Monday at 9 AM, will be a few hours rather than 3 days. It has various other reports like assignee time, status entry dates, average/sum reports by any field(eg. average in progress time by project, average cycle time by issue creation month). And all these are available as gadgets on the dashboard too. Here is the online demo link, you can see it in action and try without installing the app.
If you are looking for a free solution, you can try the limited version Status Time Free. Hope it helps.
Hello @kavita.desai
Our team at OBSS built Timepiece - Time in Status for Jira app for this exact need and more. It is available for Jira Server, Cloud, and Data Center.
Time in Status allows you to see how much time each issue spent on each status and each assignee.
You can calculate averages and sums of those durations grouped by the issue fields you select. For example average resolution time per week, month, issuetype etc.
The app calculates its reports using already existing Jira issue histories so when you install the app, you don't need to add anything to your issue workflows and you can get reports on your past issues as well.
Time in Status reports can be accessed through its own reporting page, dashboard gadgets, and issue view screen tabs. All these options can provide both calculated data tables and charts.
Using Time in Status you can:
EmreT
For a readymade solution, you can try out our plugin,
The add-on provides the time in each status for the entire lifecycle of the issue and you can filter by issue type as well. You can also combine your statuses to define your Resolution time and also extract the transitions history of the issues. The main features of the app are as below
