Issue Checklist ,Template Restriction View & Edit
Harshang Trivedi
September 11, 2019
Hello All
We are using Jira across the Wide user groups. Each Group has its KanBan Board and Project. Also , each group has its own checklist and also has an admin who will maintain the Checklist.
Is there any option in Issue Checklist Pro to put a filter to display a specific Checklist available for the user to add? Also is there anyway to restrict the user to edit the check list template?
addon-com.gebsun.plugins.jira.issuechecklist
Jack Hunter _HeroCoders_
September 11, 2019 edited
Hi @Harshang Trivedi,
When it comes to permissions/restrictions:
  • template authors can modify their own templates
  • project admin can modify all templates
You can check the following documentation page for more details: https://gebsun-support.atlassian.net/wiki/spaces/IC/pages/1181745213/Permissions+for+templates
There are no filters in the Manage Template dialog yet (we have it on our backlog though). But, if you use some of the templates very often, then you might consider using default template/checklist in a given project (can be set per issue type): https://gebsun-support.atlassian.net/wiki/spaces/IC/pages/776896599/Setting+a+template+as+default+checklist
Let me know if that helps or if you have more questions or suggestions.
Jack
