When I add the embed html code given by the "Embedding the issue collector" wizard in a Sharepoint page nothing changes on screen. Consulting the Firefox developer console shows the following errors (url edited):
The resource from “https://INTERNAL/collab/env-c1/GIS/pages/Home.aspx?collectorId=d17513c3” was blocked due to MIME type (“text/html”) mismatch (X-Content-Type-Options: nosniff).
Loading failed for the <script> with source “https://INTERNAL/collab/env-c1/GIS/pages/Home.aspx?collectorId=d17513c3”. Home.aspx:713:1Loading failed for the <script> with source “https://geobits.atlassian.net/rest/collectors/1.0/configuration/trigger/d17513c3?os_authType=none&callback=trigger_d17513c3”.The embed code is:
<script type="text/javascript" src="https://geobits.atlassian.net/s/d41d8cd98f00b204e9800998ecf8427e-T/-fzx0du/b/3/9edb822e6c4db3635f27806476c088cb/_/download/batch/com.atlassian.jira.collector.plugin.jira-issue-collector-plugin:issuecollector/com.atlassian.jira.collector.plugin.jira-issue-collector-plugin:issuecollector.js?locale=en-US&collectorId=d17513c3"></script><script type="text/javascript" src="?collectorId=d17513c3"></script>
The only related discussion I've seen so far, GitHub Power Up not working, indicates this is something that needs to be fixed on the Atlassian side.
Meta: I had to press submit post on this 3 times before it was successful. On the 3rd time was a notice about invalid html. As far as I can tell what's written above is still correct, but I may have missed something. During the initial composition I tried several ways to stop the blockquote format and resume normal for the rest of the post but was not successful.
