I have a project associated with issue security scheme. I have some security levels like L1, L2, L3. And i have n number of users Jira.
Now my question is can we have option like if an issue is created with L1 issue security level the issue should be assigned to particular user and if an issue is created with L2 security level the issue should be assigned to another particular user. Is it possible??
Hi @Rahul
Sure, this is possible using Automation.
The rule will look something like this:
Let us know if this works for you!
Ste
@Ste Wright Automation got failed and I am getting error like " Actor does not have permission to view one or more issues, or the issue was deleted (please check permissions and issue security levels)
Hi @Rahul
Ensure all Security Levels include access for the Project Role "atlassian-addons-project-access"
All permissions in the Permission Scheme relevant to the Automation will also need to provide access to this Project Role.
This Project Role is a non-human role, which allows Apps (like Automation) to take action on Issues. It needs the Security Level access to see those Issues.
Ste
