Issue to done
Mario Amaya December 14, 2023
When I try to move the issue to done it doesn't close, how do I set up the resolution?
Mikael Sandberg
You have two options, the first one is to set the resolution as part of a post function on the transition to done. You do this by editing the workflow and click on the transition to get to the post function.
The second option is to add a screen to the transition that have the resolution field on it.
I always try and do it as part of a post function, that way you know that it is set.
