Issues don't appear on board.
Jordi May 4, 2016
I changed the task, sub-task and epic workflow to another one.
Afther changing this, some issues don't appear on board.
I went to Configure Board -> Colums. I added new columns:
image2016-5-5 10:10:3.png
However, issues fail to appear on board.
Any ideas?
Chris Dunne
May 4, 2016
Can you check your filter for the board? Use the filter in Issue Search screen and make sure it returns everything you are expecting.
Jordi May 4, 2016
Current filter applied on this board is:
image2016-5-5 10:52:26.png
Jordi May 4, 2016
If I go to Issues seems like Open issues is applied. I don't why.
image2016-5-5 10:54:23.png
