Hi There,
I have created a sprint in one of the project and moved some issues in the sprint. I noticed that a couple of issues in the sprint are showed with crossed mark which means the issues are completed/closed. but those issues are updated with opened and In progress statuses.
Can i know why those issues are showed with crossed marks in the active sprint even though the tickets are opened or in progress?
Chandra.
Yes. you are correct, those issues are striked because of the resolution. now i checked and changed it and it's working fine now.
Thank you very much for your response.
Chandra.
You're welcome, @Chandrasekhar V L
If you think, your question is answered, please check the right answer with the checkmark on the left side. With such a marker, other user can find answered questions more easy.
Thank you
Do you mean, that the issues are striked through? This means, that they have a resolution (regardless of their status).
If you don't mean that, please post a small screenshot, so we can help you better. To be honest, I don't know, what you mean by the crossed mark.
