I created a new "custom field" using "Short Text(plain tex only)". Working fine, except for the fact that when running a JQL, I cannot do a query search using the "=" (not an available option) ... only the ~ sign is available and that is not pulling in my results ... Is that a limitation of setting up as Short text ? What can I do to edit the query capabilities?
OR ...
The only other option I saw in set-up that I might use was to set up custom field as "Label", but I wasn't sure if that would impact the use of the already existing "Label" field. I certainly DO NOT want to do that ... So would there be an impact to existing Label field ?
Thx, Mark
Hi @Mark Hayford and welcome to the community!
A text field indeed has it's own type of operator(s).
https://support.atlassian.com/jira-software-cloud/docs/search-syntax-for-text-fields/
A "=" operator (I believe) can only be used with fields that have pre-fixed values (like select lists)
You do mention you get the wrong results when you query with ~ (matches), perhaps we can dive deeper in that?
hey Dirk, thx for the fast response!
With "~" I cannot retrieve two word inputs ..IE., A query such as Custom field ~ test, works OK, but a query such as Custom field ~ test results. does not work ..Assume that is probably as designed?
will indeed not work but if you add quotation marks that should return results atleast.
Custom field ~ "test results"
You can work with "required" operators or combine logic gates but if the problem was that the query failed you should already be fine with quotations.
