Using the rest API to create a jira issue. the content of the body uses Atlas Document Format. Everything works fine with simple Paragraph style content but when I try to insert a table element I receive the following error:
"errorMessages": [
"We can't create this issue for you right now, it could be due to unsupported content you've entered into one or more of the issue fields. If this situation persists, contact your administrator as they'll be able to access more specific information in the log file."
Here's a sample of my basic table code block
"description": {
"content": [{
"type": "table",
"attrs": {
"isNumberColumnEnabled": false,
"layout": "default"
"content": [{
"type": "tableRow",
"content": [{
"type": "tableCell",
"attrs": {},
"content": [{
"type": "paragraph",
"content": [{
"type": "text",
"text": "cell text"
Looks like I was missing type & version in the description node. this works:
"description": {
"type": "doc",
"version": 1,
"content": [{
"type": "table",
"attrs": {
"layout": "default"
"content": [{
"type": "tableRow",
"content": [{
"attrs": {},
"content": [{
"content": [{
"type": "text",
"text": "cell text"
Hey Bob, Glad you found the issue. I am trying to use Jira Python API myself and I am unable to create tables with the new markdown. Wondering what language were you using?
I'm actually running this through Filemaker submitting cURL commands.
