JIRA Automation - Epic not being set when child issue is created
Robert Nordstrom February 21, 2025
Hello, I hope someone can help us. We've been using JIRA Automation for several years. Recently, we noticed that the child issues being created were not getting linked to the Parent Epic. In investigating, we found the message about:
Epic Link will soon be replaced with Parent. Update to Parent field to prepare for these changes.
In our original child issue Epic Link, we had it set to "Copy from trigger issue"
We tried setting the Epic Link to "Copy from parent" as the message indicated and reran the automation with the same results. The child issue is created but is orphaned with no epic link.
4 votes
John Funk
Hi Robert,
The message was not that you should use Copy from parent for the Epic Link field, it's that you need to replace the Epic Link field with the Parent field. Then you can use the Trigger Issue as the parent value.
Robert Nordstrom February 23, 2025
Thank you, John! That makes sense. I still don't understand where to change the Epic Link field with the Parent field.
Like John Funk likes this
John Funk
Click on add fields, then click off the Epic Link field and select the Parent field  in the list.
Robert Nordstrom February 24, 2025
Got it! Thank you , John!
John Funk
Great!
