JIRA Calendar Plugin which is in server . what best plugin will be alternative in cloud
Varsha Gupta February 24, 2021
Angélica Luz
February 25, 2021
Hello @Varsha Gupta,
Checking the details of JIRA Calendar Plugin, there is a built-in calendar in Cloud that has the same functionality.
Jira Cloud
  • This app comes preinstalled in Jira Cloud instances as a gadget.
    • If the message below appears when adding gadgets to the dashboard, to click Load all gadgets in order to find the Calendar gadget app.
  • Add it to a dashboard.
    • Ensure the Due date field is part of your screen scheme so Jira has data to pull into the calendar.
Hope this helps!
If you have any other questions regarding this matter, please let us know.
Angélica
Varsha Gupta February 25, 2021
@Angélica Luz  could you please tell for Due Date Notification .which plugin will be used in jira cloud
Angélica Luz
February 26, 2021
Hi @Varsha Gupta,
Using built-in features in Jira, you can use a Filter subscription. You can filter issues, using the JQL:
resolution is empty and duedate <= 120d
For more information, check the  Subscribe to search results section on the documentation below.
Also, check this blog for more details:
If you want to use an add-on, I found some option on our marketplace:
FREE
