I want to connect PowerBi to Jira (cloud).
1) What's API can I use ? I'm trying "REST API", is it good ?
2) What JIRA's rights I should have to do that ?
Hi @Chreos.Assi
You can also use Power BI Connector for Jira plugin https://marketplace.atlassian.com/apps/1221150/power-bi-connector-for-jira?hosting=cloud&tab=overview
This plugin allows you to import data from Jira to Power BI and create informative dashboards and reports in minutes.
Fast & responsive support is here to help you to install and configure the app. Please let me know if you have any questions
How to connect Power BI to JIRA using Rest API and without third party app https://community.atlassian.com/t5/Marketplace-Apps-Integrations/How-to-connect-Power-BI-to-JIRA-using-Rest-API-and-without-third/qaq-p/2255960
AIO Power BI Connector for Jira app can be used to easily connect Jira and PowerBI\
It is the #1 selling Power BI connector for Jira on the marketplace and is used by thousands of organizations world wide, including several fortune 500 companies.
It is available for all the three platforms Cloud/Server/Data Center.
Link to marketplace app page: https://marketplace.atlassian.com/apps/1219072/aio-power-bi-connector-for-jira
Documentation link: https://aioreports.atlassian.net/wiki/spaces/APBCFJ/overview
For any questions or issues, please email us at support@aioreports.com or log a ticket at http://support.aioreports.com/
Regards
AIO Support
Cloud only allows access over the UI and REST.
This is a great relief to so many of use who have been telling people not to try SQL because you will get it wrong.
Anyway, you will find that the REST API respects the permissions in the Jira you connect it to.
