Hello, I have a Jira SSL Certificate and I will like to install the certificate on my JIRA server.
Please, I need a simple step of installing the Jira Certificate in JIRA. The current certificate is about to expire, and I need a simple step to install the certificate.
I will appreciate your response. Thank you
Have you tried to run through https://confluence.atlassian.com/adminjiraserver/running-jira-applications-over-ssl-or-https-938847764.html ? Where are you blocked in that, and what choices did you make about where to terminate your SSL (Tomcat or a proxy server, and which one if you did go with a proxy)?
