JIRA automation, and a working example of the Split function for smart values
June 2, 2020
Greetings, community!
Who has a working example of using the Split function accessing the values in the result array?
I am able to split things, and I even figured out how to work around non-splitting characters.  (For example, replace periods with another character prior to split.)
But, when accessing the values, the results are consistently:
  • {{field.split("x")}}    Returns the array correctly.
  • {{field.split("x").first}}    Returns the first element of the array correctly.
  • {{field.split("x").second}}    Returns an empty value. Same for other numbers.
  • Dereferencing the array with [n] notation does not appear to work either.
Thanks for any help you can provide!
2 accepted
8 votes
Peter Reiser
October 12, 2020
Example on how to extract the email domain of a reporter
{{reporter.emailAddress.split("@").get(1)}}
We use this in Jira Automation to exclude certain domains to be added to certain organisations
Mark de Bont [Terberg] October 26, 2020
Thanks, this is really usefull. Was looking for this ;-)
October 26, 2020
Thanks, @Peter Reiser for that example.
mb
Hi @Bill Sheboy @Peter Reiser I am also struggling with the regex split function. I am trying to use the split function on the "responders" custom field (I created a smart variable to make it more readable) in order to retrieve the user ID from the value. Unfortunately, my variables are always empty.
Do you have any idea what I am doing wrong?
Not even splitting by "user" gets me anything.
{{responders.split("user").get(1)}}
I suppose, I have to somehow point to the value of the responders field?
When I do a log action on "responders", I get:
Responders value is: {ari=ari:cloud:identity::user/<PROFILEID>, name=<PUBLICUSERNAME>, type=user, avatarUrl=https://avatar-management--avatars.us-west-2.prod.public.atl-paas.net/initials/M-4.png}
But after using the split function, the new variable is always empty.
Here's the link to my problem that I am trying to solve.
mb
The regex that I wanted to use initially was:
{{responders.split("user/").get(1).split(",").get(0)}}
January 30, 2024
Hi, @mb
To help focus the conversation, let's use your question / thread to help solve this.  Thanks!
https://community.atlassian.com/t5/Jira-Service-Management/Send-email-to-incident-responders/qaq-p/2592921
Like mb likes this
6 votes
June 12, 2020
Hi, community!
After a comment from an Atlassian developer on another question, it appears the problem is the documentation for text functions, not the split() function itself.  The gap may have been caused when the information was ported over after Atlassian acquired the automation product.  Who knows...
Split produces a list, and lists are not accessed as .first, .second, etc. as described in the doc.  Instead, they use function returns (note the parenthesis) and numerical, not literal indexing:
.first()
.last()
.get(n)  where n is the 0-based index for the array.
Please see here for more details on list access:
https://support.atlassian.com/jira-software-cloud/docs/smart-values-lists/
Nick Muldoon
September 16, 2020
Thanks @Bill Sheboy, you saved me a ton of stuffing around. Greatly appreciated!
Nick
Like Bill Sheboy likes this
September 17, 2020
Nick, I am glad that helped you.
__Bill
Nikola Gaydarov July 1, 2022
Hi @Bill Sheboy , can you delete an item from the array? Say I am looking for cars, get(0) = BMW; get(1) =Audi and get(2)=Boing, so I want to delete the last one and if I make split().size to receive 2 instead of 3. Can this be done? Cheers, Nikola
July 1, 2022
Hi @Nikola Gaydarov -- Welcome to the Atlassian Community!
I have not tried that, and...
You could probably use match() with a regular expression to expand the other values into a new list/string, and then reform the list, either directly or with join().
You could also try using smart value list filtering to create a new list be removing the non-matches.
Sam Huawey
@Bill Sheboy it is a little bit late but I have an issue with the split function.
lets suppose mytext is DB-223, DB-224, DB-225
I use code
{{#mytext.split(", ")}}{{index}} - {{.}} {{/}}
According to documentation split returns an array of strings and the code above should return
0 - DB-223, 1 - DB-224, 2 - DB-225
But it returns
0 - DB-223, DB-224, DB-225
Looks like it does not think that split produces a list.
What I am trying to achieve is to convert text DB-223, DB-224, DB-225 to
<jira_url/DB-223|DB-223>, <jira_url/DB-224|DB-224>, <jira_url/DB-225|DB-225>
Is there any way to do that using split function and list notation #?
Sam Huawey
Answering to myself :)
I was able to achieve it by replaceAll
{{mytext.replaceAll("(DB\-\d+)", "<jiraurl/$1|$1>")}}
