how we can use JIRA board for proper reporting purposes…
We would lie to see statistics for Sprint in total – how many stories, how many was done/cancelled/ etc
Next one we would like to see aged report – how many stories sitting from previous sprints and not finished yet.
Anuradha
@Anuradha Yadav Jira Boards cant be used for reporting purposes, its just a visual display of progress happening in Sprint.
For reporting purposes you can check reports section (even tough it has its own restriction)
More more detailed report and analysis (how many Epics, how many spill over, how much hours spent etc...) Structure plugin is best.
I would research Jira dashboards. There are a lot of different gadgets that can help you achieve your goals. You might find the following articles helpful - what-is-a-jira-dashboard
Hello Anuradha Yadhav,
If you're looking for a plug-and-play application that tightly integrate with your Jira Software, ensure 100% security for your data, give you plenty of visualization, dashboarding, and sharing options, please do check out the Analytics Plus app from the Atlassian marketplace.
In addition to the above, you also get 150+ prebuilt reports and dashboards built using industry-acclaimed metrics and KPIs.
Disclaimer: I'm a product expert for Analytics Plus app.
