How tou count the number of specific subtask?
using JMWE
when submitting from status A to B, it will calculate the specific subtask.
Subtask A
Subtask B
I would type something along the following lines:
{% set subTasks = issue | subtasks("key") %}
{{subTasks | field ("fields.issuetype.name")| filter ("Sub-task") | length}}
You can rename the word "Sub-task" inside the filter ("Sub-task") with your own name of subtask
hi @Alex Koxaras -Relational- ,
sorry, one more question,
if there is one more condition, where the subtask status that is counted is only the Completed status,
then, how to achieve it?
you can use this script:
{% set subTasks = issue | subtasks("key,status") %}
{{subTasks | filter (["fields.issuetype.name","Sub-task"]) | filter (["fields.status.name","Completed"]) | length}}
